gideon
Instaled the new pump and the ski started after 3 attempts, ran like it did the day i got it reved it up and sounded great. I eventually stopped it with the stop button and now it doesnt want to run again. Starts for 3 seconds and stops. All I did after the stop is tightened the bolts on the top of the fuel module. I then removed the whole module and all seems ok. I did a test outside with just the pump and assembly (fuel hose and sliding aluminium tube and there is no leaks, also the pressure is so great that I cannot keep the end closed with my thumb. Wish I had a pressure guage
I am now lost. 2 different pumps and the same result, starts, runns till i stop it and then doesnt run again. What could it be? Could the injectors be blocked? Guess not otherwise it wouldnt start at all. Battery voltage is at 12,8 when idling.
I didnt change the in line filter but if I removed the connector just before the fuel rail fuel does come through when I have the lanyard on, could this afecting the pressure?
