Thanks. Don't run it on the hose too long though, i would hate for you to cook your carbon seal.I can try and check mine when I get home if it's not raining
Yea, I'm really hoping this is in fact normal, but somehow I doubt anyone out there has ever run their boat without the PCV valve to check this. It seems bizare that this much smoke is normal, but then again, this is my first encounter with a 4tec engine, and I don't know how superchargers affect things. The motor has plenty of power and perfect compression. It's hard to believe that the rings are shot... I will still do a leak down test once I get the pump cone off.
I got side tracked last night when I finally got to the nozzle. It turns out that my GTX and the RXP nozzles are exactly the same. The only difference being is that the RXP one has a gimbal ring for trim control and the GTX just has spacers to take up the extra slack where the ring WOULD have been. So having two, I decided to try and port one to a wider diameter, as suggested by my friend [MENTION=52309]MPower[/MENTION]. I used these coarse honing stones I had laying around and widened the nozzle from the stock 83mm to 84mm.
Today, i will go and fill in those vestigial siphon holes with jb weld and sand smooth. Hopefully, having the ability to move more water will give me better hole shot and eliminate the cavitation when I give her full power from stand still. Even when water enveloped the carbon seal and stopped all possible leaks, it still cavitated under that condition. At this point, I can't imagine what else it cam be but improper pump setup.
The sc has all new seals too though. Oem and correctly assembled. I guess I need to get a boost reading on the manifold? Anyone know what the specs should be? Why would sc leaking boost push steam into the crank case?I wouldn't look for intrusion into the cylinders, if it's the head gasket, you might be pushing cylinder pressure by a coolant passage and crankcase junction, or you could be pushing boost through the turbine shafts seals.
Wait, are you a DSM tuner? Only eclipse I know that can take 30psi of boost is a built 4g63. Those were awesome cars. I had a gen 1 a long time ago.I was thinking it might be a possibility and the, vapor (what I will call it for now) might be blow by.
On my car, Mitsubishi 4 cylinder turbocharged, I have blown the dipstick out while at the drag strip. This is while the engine sees the 30psi and 6000+ rpm. Moving pistons at that rpm create a lot of crankcase pressure.
Does the vapor continue all day? Could it be condensation? Does it stop after the engine has been run for an hour on the water?
Coolant level same or dropping?
Hmm you know, I have not thought to do so. I'll do that tooHave you pressure tested the closed side of the cooling system?
