IDoSeaDoo
Ya, it takes very little throttle to get it up to speed and on plane. I think it cavitates during the whole rpm band. Anyone know if aftermarket carbon seals are as good as oe?Cant wait. Boat looks like it has plenty of power now. Looked like it was going pretty quick at half throttle.
Lol I don't want any more top end, this thing gets scary fast. Maybe I'm just new to it and not used to it, but I think 50mph is fine for this hull. I'm afraid to break it lol. I do want more holeshot. My gel coat dye should come in tonight, so maybe I'll paint that ride plate and seal it up properly. That might be where it's coming from, as the carbon seal seemed okay. The little driveshaft hat had a few light scratches on it though. Very small, but that may be affecting it too.If after sealing it up, etc you still have cavitation, I wonder if you might be able to update (down-date? downgrade?) to the seal/bearing carrier for better seal.This seems like phase 2 or 3 in grand scheme of things, but something to consider when it comes up. looks like TONS of power, perhaps a more aggressive impeller pitch might also help gain even more top end doesn't look like you are needing any bottom end power (next year or two)...Video was awesome! Enjoy the fruits of your labor!
You're saying that I'm boiling the water at the trailing edge of the prop? Damn! I'm not sure that's it as I can hit max rpm even at full throttle. I think I'm cavitating the whole time. I want to eliminate the obvious culprits first, like new carbon seal and properly sealed ride plate. Damn that pump cone is expensive. Anodized aluminum my ass, it's made of platinum! I don't know the nozzle on it, I know that it's for an rxp. Also, I bet if I can find someone with a 3d printer, I could print up some variations on this coneI built a hot rodded Sportster 215 years ago, bigger charger, fuel, cooler, etc. Cavitation was obviously an issue. You have some options just by swapping out the steering nozzle and exit nozzle. Any idea whats on it now? 83mm or 87mm? Also, a lucky 13 pump cone with adjustable washers is a great tuning tool and obviously a more aggressive prop (3 blade skat)
Ya, I wish this thing stayed lost in the mail. I can't even get polyester to cure on top of this crap. What the hell do I do now... can't sand it off, it's still tacky, can't seem to put a crust on it....I'll second the US composite. I've spoken to them and they will tell you everything you need to know. Ninety that you bought white and not neutral. Good answers are a phone call away, I'll always lean on a pro for a new project.
Oh ya, works great!Did you do any vts testing?
