It ran GREAT! Of course there were a few snags, but the boat is a BEAST!! :thumbsup: We finally put her in Saturday. I finished the wiring and tested all the circuits, got a big box of tools together and off we went. The steering cable was a pain, the linkage kept binding when you turn it all the way. That made it especially tricky near the dock when cranking all the way triggers the RPMS to increase. It was seadoo's answer to make the boats more maneuverable at idle. Works well if the steering is free
Anyway, we got out and just idled around, keeping a close eye on temps and leaks. Then I started playing around with the throttle
The boat experienced a lot of cavitation. You can't punch it from Idle, it just spins the prop and bounces off the rev limiter. I suspect a badly sealed ride-plate. I'll fix that once my gel-coat dye comes in. I want to gel coat the bottom of it. The top is painted with automotive 2-stage.
Once the boat is on plane though, it's a monster. Forgetting I had the trim up, I floored it. It got up into the 50s, but started getting all squirrely. I eased her back down, adjusted the trim and floored again. She topped out at 50mph that way. I'll experiment more when I'm more used to it
Anyway, I noticed that oil was again seeping from around the valve cover. I pulled the dipstick, and it blew off a ton of air pressure, along with some oil. Made a huge mess. The TOPS valve is shot. I tested power, and it is getting it, but when you plug it in, it just makes a weak whining shuttering sound. I'll probably just take it apart and gut it. I don't see a use for it anymore, since this boat will not be turning over much.
My fears about the cable snapping were realized on the first trip out. The binding was a result of the cable bending as the steering assembly pulls it out. This repeated bending finally caused it to snap. Luckily we were right near the dock, and there were almost no other boats around, so we used the engine in short bursts to propel us fwd while I steered with an oar
I've already installed the original cable and calibrated it. Had to bore the thru-hull hole in the plastic pump base plate.
I also finished the heat exchanger mount bracket and cut the OE hoses to fit the new configuration. It all rits rather nicely. Just got to finish securing that to the hull and mount the strainer, and that's done.
Also, I fully tested the fuel tank for leaks by filling it up and driving around with it (some 40 miles or so). No leaks anywhere! I plan to take her back out tomorrow after I sort the TOPS issue out, and seal up the leaking drain plugs.
Video will come later today once I find non-restricted WIFI.
