kenfyoozed
just replaced the reeds and put on new gaskets at each joint. Now when trying to get it to idle it will run fine for a about 10 secs and then its starts to rev up and I have to kill it. Everything is torqued down as it is supposed to be. I can only assume an air leak. Im going to try and richen up the low screws and see if that helps. Otherwise what do I do?
