wernerml
With bad fuel you can get corrosion or varnish. Just some carb cleaner and some que tips. Most of the things I see here have to do with the Gray fuel lines and deterioration due to alcohol in the fuel. If you have black fuel lines you are probably ok. If your fuel filter was really clean then you might put off trying to clean the valve until you fix the other stuff.
The center of the fuel selector knob pops out and there is a screw underneath. Pull off the knob then take off the nut then the valve will push back into the hull. Pull it out by the fuel lines.
To put it back in the fuel lines are stiff enough to push it around until the valve shaft pops through the hole behind the driver's knee. Probably a two person job and a pair of needle nose pliers to grab it when gets close enough.
