787 RFI low power
Yes it won't hurt to check off the basics did you swap ecu from the other machine and when you say bog does it work itself out and hit the rev limiter at wot on trailer.and when it is bogging does the engine rattle around.i keep for getting it's a 3 d and not a Gtx or gsx rfi
Mine is a little different then pedec. Mine seems to rev up quite well on the trailer, out of water. Put it in the water and it seems to not hit the higher RPMs and once it peaks at a mid rpm and is on plane cruising it will start to miss. when it is missing, it is not rhythmic or in a pattern, just random misses. I will do some more swapping today.
Is the ECU the box with the fuses on it right in the peak of the bow? Then there is another box with two round connectors on it on the right hand side, further back.
I tried to cover up intake and run ski and it ran the same or worse. I then took duct tape off and there was no real change. Lots of smoke while running on the hose. I swear I swear I could feel a blow out intake when I took duct tape off is that normal.
Ecu has rectangular plugs going into it and facing away from battery. VCM has the fuses in it with rounds plugs on top.
Ok just tested again with intake covered like in pic and a piece of paper on side of duct tape to see if sucking or blowing and it sucking paper in. Once I take duct tape off intake seadoo seems to run not as rich revs a little higher but still bogging or not revving up. Still seems to have a little blowback out intake while running or idling. The tape over intake made 3d even run richer.
Please start your own thread. It gets confusing when there’s two different people working on different skis in the same thread.
@Poormanracing Might finally be on to something here. This is the new info I have:
Installed the fuel pressure gauge and I get about 55 psi with it running and it barely leaks down anything after 10-15mins after shutting down.
I decided to pull the electrical plug off of injector #2 and the ski started without that connected and just running on cylinder #1. However, if I pull the plug on injector #1 the ski will not run or will run for a second or two and then quit. So, this tells me (correct me if I'm wrong) that cylinder 2 is not running due to spark or fuel. To double check, the good ski will run on either cylinder when performing the same test.
I installed the inline spark testers and both have consistent spark from what I can tell. Sooooo, I would have to guess that injector #2 is the root of the problem. Does this seem logical to you?
RFI skis idle on one cylinder so that doesn’t exactly pinpoint the issue.
Injectors do go bad so might not be a bad idea to swap them out for known good ones.
I know they idle on one but the good ski I have will idle on whichever one I have plugged in (leaving one at a time unplugged). The ski I'm working on will only idle on the #1 cylinder. Might fire for a couple second on #2 but then quits. I'll try and swap them and see if that changes the outcome.
Swapped the injectors and the problem stays with cylinder 2. Will not run on cylinder 2. I feel like this is why I feel like I have half the power across the full range. Is the ECM the next logical thing to swap if it seems like I'm getting good spark but not fuel? I will swap the coil in the meantime just so we can eliminate it.
My 3d will idle on pto or mag cylinder with one spark plug unplugged.
Yeah, I'm testing with unplugging one injector at a time and mine will only idle on the front cylinder (mag?). If I unplug the second injector it won't run. So I feel like maybe my problem all along has been only running on one cylinder... Or the second cylinder working intermittently.
If I choke the airbox while trying to only run on cylinder 2 it still won't run. I've also since put a brand new spark plug in to eliminate that.
I have now switched the ECM, the OTAS (pictures attached) as well as the coil, the plug wires, new plugs, fuel pressure tests at 55psi and drops to about 30 after 30 seconds of turning it off now. Seemed to hold longer before but that's what it is. Fuel pressure stays constant from idle up to as high RPMs as it will go and whenever it misses, there is no change in the fuel pressure. I was looking for the water regulating valve to see if maybe the exhaust is filling with water and not draining causing me to not hit the higher RPMs but can't find it.
Also, if it had kicked into limp mode at some point, does it auto reset or do I need a scanner to get it out of limp mode?
Sounds like you are getting closer to problem. Did you get a look at cylinder and piston. Is cylinder 2 the one with lower compression test.
I couldn't see in very well but maybe I will pull the raves again and take a better look. Both cylinders tested the same at about 135 with a cheap tester.
Your 04 Ecm looks different than my 05. Sure nice to have extra 3d that is running good to switch parts.
Mine test 155psi both cylinders with a good quality tester which is what I think is good or what they should be. How does it start?
