mattrourke
I will take a look. I will try and do a leak down test before I fully rip it apart. I'm guessing the leak down test involves pressurizing the cylinder and seeing how fast it leaks down... This is a new one to me but see it refered to a lot.Be interesting to see if once you get piston out if you can see more blow by on piston with lower compression. Blow by is dark colouring under piston rings. Or scuffing on bottom of piston from ring being worn and piston rocking. How many hours will you put on 3d in a year. If less than 30 hours a quick
Fix might work but if put 100 hours a year on might need more work.
I will probably put 30-50 hours at most per year on it. I'm in Canada and so only really get to hit the water june-august. It's sad but that's why we have sleds as well.
