BRP XPS-II oil
Is this is the right one?
http://store.sea-doo.com/product/528502/293600100/_/XPS_2-stroke_Synthetic_Blend_Oil
And how many do I need? It costs $40 to ship to Canada. I will call around to see if I can pick up any locally.
It's a special gift! (jk), it's the infamous fuel water separator cup that unscrews and then leaks air and makes your motor run horribly as air gets sucked into the fuel lines.
Unscrew the cup to clean and check for water contamination, the plastic cup can crack and the o-ring inside is known to leak if the cup is not tight, the threads can strip or the cup can crack if overtightened.
This device deserves your respect, it's job is to keep trash from migrating from the fuel tank into your carbs, it CAN cause running problems if it leaks air inward.
I do not know if the filter is a coalescer filter or not. If it is, it is designed to stop water. A coalescer filter normally does it's job very well and once there is water against the screen fuel will not make it through the filter. It is suppose to gather against the screen until there is enough to create a droplet. Once the droplet is heavy enough it falls to the bottom and stays there for the simple fact that water is heavier than fuel.
If you cleaned the filter with water, it can trap water within the filter and cause a hard time to get fuel through it.
So either blow it dry with a compressor or pour a bit of fuel into the inside and let it run through the filter.
Red black and blue wires are for the add on fish finder and CD player. I should add a cut off switch to prevent it from draining the battery.![]()
Sent from my iPhone using Tapatalk - now Free
Ok i figured it out. Put on the inner filter first the screw the cup on :-D
You already have a cutoff switch. its right there in your pic. Looks like the wires go to it. Pull that battery switch out and make sure the positive wires for accessories are on the common post with everything else.
Good lookin boat by the way. glad you got it into your garage. I didnt think it looked very safe on the street in that hood you live in.![]()
Rule-Mate is the bilge pump to remove water from your bilge and push it overboard out the starboard thru-hull fitting.
The joke is, this device can be used to increase bilgewater circulation.
Yep,, sorry so slow,, got busy...
Get the gallon size!! (Or the 3.875 liter size)
marine spray 9
Can the pump totally drain the water inside the bay? It still have some water at the bottom. Do I need use a rug to get the bottom dry?
Is the water in the bottom going to damage anything?
The bilge pump is there to keep the boat from sinking in the lake (joke: and keep bilge water recirculating).
So the bilge pump kicks in by a float sensor somewhere then.
