NoahDobie
I rebuilt the fuel pump and pulse cover again, so that must be good if there was an issue. It will fire right up if I crank it but it only 1 cylinder seems to get hot after I run it for about 15 seconds. Only the PTO plug gets warm, but they both are getting spark. I think this is the problem with the ski, not the carbs.
EDIT: Yep, confirmed it. Its running intermittently on 1 cylinder but it cuts out a lot. Sometimes it will run great, but most of the time its running off of 1. Was able to pull the mag boot and it was still running at 1600rpm.
