Spider4real
Hello all. I recently assembled the bottom half of my 580 engine. And attachted the two pistons when I decided to check the rotary valve cavity to be sure it was sealed properly. It will go from 5 psi to 0 in about 20 seconds. So I want to split the case to see if I can see what's up but I have to remove and likely ruin 2 circlips. Does anyone know if OEM circlips are compatible with WSM pistons? They seem to be the only one I can get locally.
Cheers
Cheers
