My 03 155 will not start if the fuel tank full. Fuel pump seems dead.
Starts and runs fine if I drain fuel down to a third of a tank.
What's happening?
The fuel pump is at the very bottom of the pickup so it is always submerged in gas. The problem is that the tank is not venting well enough. As stated above, leave the gas cap off or very loose and I'll bet it runs fine. When there isn't enough air in the tank, it can't vent quick enough to keep itself running. Your check valve in the vent line isn't working or your vent line is plugged up. Simple to fix/replace.
So you've tried it with the gas cap off? It's possible you have a connection problem that shorts the wires out when you have a full tank. Pull the fuel pump and should be a simple fix.
Update: I reassembled the pump assembly with new connector and cleaned contacts on the pump itself. Filled it up. It went 300 yards and died. BRP dealer sold me an OEM pump assembly ($840 CDN plus tax). I installed the new pump assembly. Pump does not power up.
Thanks everyone. All sorted out. The ground to the fuel pump is supposed to be provided by the ECU but it's broken. I supposed a direct ground to the brown-pink wire. It works but Check Engine is on the display.
Anyone know how to get rid of check engine?
The fuel pump is a ground-side switched circuit controlled by the ECU. Power comes from the MPEM. If the driver in the ECU goes bad, the fuel pump will not run. I had a fuel pump driver fail in an ECU last week, but a freaking ECU is expensive, so I ran an alternate switched ground wire to the fuel pump. It works like a champ, however it will set a P0231 fault (fuel pump shorted to ground) DTC from now on.
