ctaylor
After having let the ski set during the off season it would sputter and not run. Of course, its "Water in the fuel" thanks to the ethanol gasoline additive, (I'll leave that political discussion out of it) And Of course I did add Stabil to the tank. Now..... you do know what must be done, drain the tank. Well that did not work because you can't get the siphon hose all down completely and in and around the bottom plus the fuel filter(s) needs to be changed. Bottom line is that I could not get to the top of the tank to remove the fuel pump assembly to gain access to the bottom of the tank. They say that 85% of problems with outboard engines is water in the fuel. This is a disaster to not be able to clean out the water in the tank. I understand it's a good idea for safety to have the pump and filter in the tank. But the tank needs to be accessible.
