J jspillers New Member Jun 1, 2009 #1 i got a 90 sea doo sp and it didnt run so i got it to run but there is no tank for the oil and fuel to mix i need to no the ratio thanks
All Things Custom New Member Jun 2, 2009 #2 I run most skis on 50/1 make sure the oil pump block off has been done or you will be running super lean and causing damage. a small plate bolted under the carb on the rotary valve.
