Just don't change out the port and stbd lights with LEDs. That is a big no no. Has to do with arc of light, viewable distance away and degree as to when the light comes into view.
JPass like your upgrades. Did the Hydro Turf two years ago (best of my upgrades) and would like to upgrade the lights to LED's. What LED's did you use ..like manufacture, watts, Model number and where purchased etc. Hate to order something online and find out it doesn't fit. Thanks in advance.
If in the same housing your are is probably within specs. I'm on my phone and didn't open your pics.
If they are where they were and in the IEM housing you will likely never have an issue.
JPass, I know the nav lights are different. Probably the anchor light is also different but the courtesy lights should be the same. I'll just remove the 12 volt bulbs and take them to the local Discount Auto store and have them match them up with LED's. Thanks again and have a fun and safe 2016 season.
Just got my boat back from the mechanic. I think a dodged a bullet. I decided to have my pumps rebuilt, seals and bearings replaced. The boat is an '07 and everything inside was original with 255 hours. Upon pickup, I was informed that the seal in my right pump was badly degraded and the grease was beginning to burn. I am posting this, because I would like to remind everyone that an OEM rebuild kit is definitely worth the time and money... If I would have continued to use it, I would have been in for an extremely costly repair, after the fact.
Eclipse : Had you been inspecting them seasonally? Or was this the first time they had been opened up? I'm trying to figure out how much I should be concerned about mine. I check them every season.
Funny you should ask. I was a little baffled myself, and I think someone on here could shed some light. I purchased the boat last year, so I didn't have any records to go on. The first thing I did, was bring it to my mechanic. I wanted a full service, and everything checked over. I did ask for the jets to be greased. In my mind, that is where you remove the cone, and fill with grease. I did not ask for the pumps to be opened, and they were not. I am a little OCD with taking care of my vehicles, and I flush it after every use. When I brought it in, he asked if the bearings sounded different when I flush it. Toward the end of the season, they did have a higher pitch. He suggested that at nine years old, and 255 hours, we should order two OEM kits and replace the bearings and seals. I agreed. As you can see from the post above, it was a good call.
So, with my limited experience, and a total of 155 hours using new-to me Sea Doo's, I would think an inspection and rebuild should be done at 200 hours, depending on driving style. I tend to spend most of the time cruising at 5400 RPM. In the time I have owned it, it has seen a total of about 3 minutes at WOT. So, if you are more aggressive, I would inspect at 100-150 hours.
If you do decide to pull and inspect, please let us know how many hours, and what you find!
And, that's the question... How long before you crack those pumps open and inspect/rebuild? Is going by sound alone a good indicator?
Very good information. Thanks for sharing. I'm curious about my own. I got my 2011 Challenger with about 70 hours on it. I did 100 this past season. When I took it to get winterized they also do an inspection on everything. However they said the bolt threads holding the jet in got corroded. They said they visually inspected it but next time they want to take the jet out and would have to break the bolts and put new ones on. They said the corrosion was a common thing with these and it was because of cheap grease that seadoo used? Anyone else heard of that?
