dobbinshabby
I have a 1999 yamaha xl760 waverunner that i just picked up along with a 92 SeaDoo SPI, anywho the reason i'm asking you about the yamaha is because when i asked about the sea doo and got super quick feed back with accurate answers and this forum is great so i'm just giving it a shot with you guys to see if you might just have the answer before you kick me to Yamaha specific forum.
Anywho this is the problem,
Its a 1999 yamaha xl760 that was apparently using too much oil. So i disconnected the automatic oiling system and changed it over to pre-mix, no big deal. Well we get to the lake and on the first run i go wide open throttle and it runs up to 30-35 mph and suddenly dies, as if it just suddenly ran out of fuel. The thing will idle, run half throttle, and slowly all day long with no problems yet when you cram it, it runs up for a bit and then just dies. Starts right back up almost every time also. The few times it does not start right back up, you hit the starter and it acts as if the battery is dead or the motor turns SLOWWWLY for like 1 rotation and quits, that may be nothing but i thought i would mention it. So all in all the problem is when you hammer it, after a while it just spontaneously dies as if it has run out of fuel. The time between when you go WOT and when it dies is not always consistent, it may run for a while and then die or pretty much die right away. Meanwhile the dash is flashing a "No Oil". I'm not sure if it has anything to due with going to premix or not.
Anywho, whatever answer you can give me i appreciate and bear with me about asking you about a yamaha.
Thanks in advance.
Thanks in advance.
