Well ladies and gentleman, since I love this forum and I get so much help on here, I wanted to contribute a picture by picture tutorial and explanation on how to remove your seats and reupholstering them. If someone else had this write up, oops, here is another one.
Getting to the bolts under the seats behind the gasoline tank is torturous, also, I put a fan to get air in there, I believe its dangerous working so many hours in the engine bay and only breathing gasoline.
And questions please ask
Here it goes:
First, the bolts are connected here:
Ok there is a bolt under the Starboard side (right hand side) of the boat under the control lever to the rear, is easy to find...
Here is the first bolt right on top of the gasoline tank
You have to remove the cup holder to get to the bolt (port side - left hand side)
I think Im pretty smart, I attached a electrical wire to my socket wrench so it doesnt fall inside the hull (im always dropping things, it is very convenient in case you drop your socket wrench), I found a old ac adapter that I didnt need anymore and used that wire.
Also when you are removing the bolts be very careful you can drop your bolts under the hull.
I recommend a fan blowing air in there I was getting dizzy its hard to be there for so long breathing fumes
Ok this is the first round of pictures, next will be applying my new upholstery!
I think Im being a little bit of service!
