Looking through the shop manual and other threads the process was to press the start button without the key on the post, within 30 secs, check the voltage between the pulse line (purple/yellow) and ground while rotating the wheel.
The analog and digital (infocenter) speedometers are connected in parallel, does that mean that both gauges are faulty if neither reads a value, even though the voltage jumps between ~7 and ~7.5? I do see earlier in the thread that it looks like voltage difference should be several volts not just tenths of volts, perhaps the 5.6v zener diode in the sensor has failed (if I am seeing readings in the 7V range).
I may rig up a small frequency generator and feed the gauges with a pulsing DC signal to see if they register something . . . .
