SS41 is $6.40ea, at Mouser Electronics I just ordered all 3 parts under $10 shipping cost more was $20Thanks for the reply. Never did a voltage check. I did check the price of a sensor and decided it was working well enoughLooking at the cost of an SS41 and a diode (my time is free since I am retired) and your excellent instructions , it is not working well enough now.
I just looked and the SS41 was $4.32, did you order the correct one? You need part # 785-SS41.SS41 is $6.40ea, at Mouser Electronics I just ordered all 3 parts under $10 shipping cost more was $20
Can $ exchangeI just looked and the SS41 was $4.32, did you order the correct one? You need part # 785-SS41.
That is the exact SS41 I used, just make sure the diode has the same specs as the one I have listed.I bought 3 Honeywell SS41's for $10 shipped to my door off EBAY. I would rather get a name brand since they may have better quality control. I am waiting to see if the picture and description in the ad were true. I also bought 3 no name Zener Diodes for $8 same way. I could have driven for an hour round trip and picked up the diodes locally for a quarter each. Didn't see the SS41's listed being in stock at the local supplier, but they may have had them. Traffic is terrible around here, Seattle area, so I'll pay a few bucks more just to not have to deal with it. Waiting for the parts to get here also has allowed the weather to warm so I don't have to lay in water and ice to remove the pick up.
When I bench tested the speedometer I did not use the 1K resister from the 12V power supply to the PU wire of the speedometer like I illustrated above. I drew the resister in just to be on the safe side, try it without the resistor. When I did this I did it quickly, just to verify I could get the speedometer to move.69DartGT
I was able to do some bench testing today, GTX1996 SEADOO Speed sensor give me voltage between 3.5vdc and 7.5vdc when spinning the paddle wheel and voltages in between faster slower. So I think that works OK. I also did a test using components same results. But I was not able to get the speedometer to work. Power applied gave me oil indicator and adding gnd turned indicator off. So that worked OK. Is there a circuit that would allow me to use a resistor pot where center lead would give me higher and lower voltages to have speedometer show speed based on voltages?
And possibility what voltages low/ hight could I apply to PU YL Input ?
Thanks
So apply power to speedometer +12v, to 1K ohm R to PU, BK -12v, OIL LIGHT comes on, add -12v to BL light goes off, so apply 12+ to PU YL just to see is needle moves?When I bench tested the speedometer I did not use the 1K resister from the 12V power supply to the PU wire of the speedometer like I illustrated above. I drew the resister in just to be on the safe side, try it without the resistor. When I did this I did it quickly, just to verify I could get the speedometer to move.
Ok, so I tried bench testing a speedometer with the 1K resistor in the circuit and it did not move. So I took the resistor out and the speedometer needle moved. I also checked the voltage of the PU wire feeding the speedometer on the ski and it was 11.5V. So using 12V to the speedometer PU wire that you are bench testing should not hurt it, but I did it quickly just make sure the speedometer needle moved to be on the safe side.Very much understand. And thanks for your assistance.
Sounds good. I hope it works for you. I revised the drawing for bench testing the speedometer. I did it this way again tonight and was able to run the speedometer up all the way with compressed air.I will give that a try. The 1k would have 12mA in the circuit. Seems not enough to activate the circuit. I will give this a go but possibly use 100 ohm then lower just to see. I'll let you know. Thanks
I wouldn't think the magnets would fail, but I have seen weirder things in life. That is odd that your sensor is not operating the speedo since the voltage readings looked good. I am beginning to think you understand this way more than I do. lolI was able to test the speedometer just by it's self.
12+ to PU
12- TO BK
This lights the LED oil low indicator
Applying 12- gnd to the BL turns indicator off
Giving PU YL a pluse tap tap activated the speed pushing it upwards of 40 + MPH
No inserted R values into the circuit works.
So the speed sensor controls the amount of 12- gnd voltage coming out on the PU YL to the speedometer more gnd it sees the faster we go.
BK OR to 12- gnd is the feed into the sensor.
I did not get the sensor I have to work with the speedometer SO looks like I'll build the circuit using the components.
Is there any chance the paddle wheel magnetic pull would fail to activate the mag switch giving it no frequency Cycle?
