DooWacka
If you have a manual, then go look up the self-diagnostics. Here is the page of interest.
Whether the beeps are short or long, 2 beeps seem to indicate a lanyard problem.
If that was all working before your fuel pump rebuild, then it may instead be something else.
If you remove and re-install the lanyard, you should get the familiar 2 beeps, and also hear the fuel pump run briefly (whirring noise). If you don't hear the pump run and then shut off, then it probably isn't getting power. Make sure that you have full battery power, then if so, check your pump connections. You did remember to re-plug in the pump and fuel sensor connector on top of the tank?
