Seadoo 951 pop off questions
I never have had issues finding the carb leak. Soap bubbles are your friend. :) Likely the gasket or one of the gaskets on the fuel feed side of the carb. Could be a loose fitting. If there air is getting out you'll find the culprit. Good luck.
Ya I found it pretty easily after I knew what to use, I had to order a new carb kit because the shaped o ring was bad and the top normal o ring, it was leaking from both so this should solve it.
Took the ski out yesterday, ran like a striped ass ape and I had everything adjusted almost perfectly, the only thing that was slightly boggy was the takeoff from idle. But I think I just had the idle screw a little low because it was around 1250 so next time I’ll play with it a little more, was kinda cold this time but no comparison to how it used to run
