Hesitation just off of idle on 1996 GSX
vogs77
I have rebuilt about 10 sets of carbs and have not had any issues, this set on my 96 GSX is giving me hesitation just off of idle, wants to bog down. The ski runs great through the rest of the range and has a great throttle response except for this issue. Mikuni kits used, all new lines, selector, and filter seal. Pop-off was checked but it was about 5 months ago and I don't remember what it was but they were very close. Carbs held pressure with no leaks either. High and low adjusters are set to factory specs. What should I change to get this corrected
Yes high and lows set to factory specs. I can try the gas cap but I did also replace the check valves in the fuel system.
If you replaced the check valves I wouldn't worry about the gas cap but make sure they are the right way around.
One thing I would try is actuate your low speed adjuster screw, just bring it out and then reset it and see if that helps. When you did the carb rebuild did you clean out all the ports? There may still be some trash in them? If you can maybe pull out the screw and run some :safe" cleaner through it and make sure it is clear. Was there green ooze in the fuel lines? I would suggest looking at the carb rebuild thread and see if you missed anything.
I would check the gap on the plugs and it sounds like it's fouling the plug on takeoff lean out the low by turning it in 1/4 turn but you may want to just run it on the water an hrs or so blowing out and reseating all the layers of carb internals.
