mikekim9182
Hello. My name is Mike and I recently purchased a 95 Seadoo XP and a 97 Tigershark Montego for $750 with trailer. Both engines run well but overall needs some work. I purchased the jet skis in order to rig them for close range southern california spearfishing and for the jet ski courses nearby. My friends and I up for the challenge. Parts have been easy to find but we had some problems in the water today with the 95 XP . I guess that's to be expected when you buy 15 year old skis.
Today was the first day we took our 95 XP after purchasing it a couple weeks ago. The xp didn't want to start at first so we changed the clogged fuel filter it ran like a champ. We noticed the vts boot was torn so we changed that and put it in the water. Everything was great. Got it off the trailer at the landing and started with the press of the button. Everything was great we were taking pictures it was a good old time. Took about 10-15 minutes to putt out of the marina and I finally had a chance to give it some gas. This 15 year old XP darted across the water like a brand new ski. After about a few minutes of riding it at 1/2 to 3/4throttle i slowly got it to plane and WOT. It was awesome. Still good. I then made a wide turn, straightened out and noticed the jet ski becoming less responsive to the gas trigger. Went back to the boat, which we were using in case of emergencey, and told my friend that somethings wrong.
Kind of hard to explain but I'm going to do my best. When we held onto the throttle at WOT the Pwc would move faster like normal and then at around 4000-5000rpm just slows down to idle speed with 3000-4000rpms with throttle still wide open. If I let go of the throttle i can feather the throttle until about 3500 to speed things up but if i reached over 4000 it just seemed like something cuts out just like above with WOT, and engines reving hard but not moving much faster than idle. Even after the problems the engine idled perfectly and i was able to dock the XP with no problem. When we flushed the engine with clean water on land it ran perfectly but not in the water.
After looking at forums I have decided to change the grey fuel lines but have heard stuff from wear rings to a rectifier problem. Can anybody help me who maybe had this problem before because I'm on a low budget and we were hoping finish fixing the 97 tigershark montego we bought with it. Please Help!
