..................... Got it
Kawi put a plastic pisser that is angled to the rear, thus enabling the water from the pisser to flow on the side of the PWC.
I have to admit that the pissers Doc is making look bitchin.
On another note, I know everyone has seen the six foot stream exiting Yami's from the rear. Does anyone know how Yami designed their pissers to achieves such a long stream?
doc when i get back from vaca, i want to get with u to get a couple of them.
Can I presume that before waters gets to the water bypass outlet (WBO), it first enters the jet pump where it is forced to the exhaust pipe, then flows through the WBO? If that is the case, then, if water is not flowing through the WBO, is a possible problem a clogged water jacket? If that is so, then, to remedy the problem the exhaust pipe must come off, right?
Where else could such a problem arise other than a clogged water jacket, WBO hose or outlet?
