From all of the Wiseco's I have seen their setup clearances are not the same as OEM because they expand at a different rate that the OEM cast pistons. If you do not have enough wall clearance you will stick a Wiseco. This is why they got a bad reputation in the watercraft market because guys would start the engine cold and ride hard like stock pistons but the wiseco's would expand faster and seize. I stay away from them for this reason.
They are a good piston but you have to make sure you have the proper clearance and warm them up slowly.
