justinb
Hi All
Tried starting my seadoo gti 2002 ski after rebuilding it.
Nothing happens when I press the start button?
I get the 2 beeps once key is installed so I assume it's seen everything?
Battery is good as I charged it up , also put the motor positive and negative on to battery motor turns.
I am assuming it's to do with the rear eletrcial box what is the process of alimnation on checking it?
I have wired it exactly how it was when I tore it all apart intact I only took the battery cable off the battery end left all the other cables as it and just disconnected it from the harness
