Quickie; '96 GTX Ground Location?
Chris03HD
Sure this is a simple one for you guys here..
My dad took his GTX apart to replace the leaking base gasket, and in doing so, forgot where a few things went while putting it back together. :rolleyes:
QUESTION: From the Neg battery terminal, where does the other end of the ground cable attach to? I can't find any where it may have been attached to!
Thanks in advance! :cheers:
starter
It's not real hard to get to if you have the air box removed from the carbs.
The starter is on the right hand side of the engine under the carbs.
You'll see a flange on the starter that has a threaded hole in it......that is where the neg cable should bolt up. Sorry, no pictures.
Good luck, DAWG
