The low speed (LS) needles only work at idle and a little above so that's not your problem. Have you checked your pop off?
Lou
By the way, can I kill the motor by doing this? I did it 3 times on Sunday, thanks!
No, you can kill the motor by running it when it's in bad tune. The fact that the hesitation clears up with the choke points to it running lean, which means the motor is on borrowed time if you don't remedy it.
you could have an air leak also causing your lean condition if the carbs are all good.
Yes.... you can kill the engine.
When a 2-stroke runs lean... you can melt a piston.
As Lou said... if you aren't comfortable digging into the carbs... send them to me. I only charge one hour labor to go though them ($65) Plus parts and shipping back to you. But... I only replace what needs replaced to help keep costs down.
PM me if you want my shipping address.
Thanks Doc,
Ok, I went through the carbs last year, and it worked like a charm the first time out on the lake, the second time out on the lake the problem started all over again.
It starts fine, and idles fine, but as soon as i apply the throttle, it starts bogging down at 20-40 percent, anything higher would shut off or rev and it wont do anything.
Ok doc, I could send them out to you, how long would it take? Please pm me your address thanks!
It sounds like there may be an air leak somewhere.
If you are comfortable doing it... then pop them back off, and check them over. And we will help you out.
I'm more than happy to do it for you... but I don't want to take you $$$ if you can do it yourself. (That's the point of this board) As far as time... even if I turn them around in a day... we are looking at about 7 to 10 days. (most of that's shipping time)
Yes... but I was thinking more like at the fuel select valve, or factory fuel filter.
Did you put in an extra fuel filter in line, before the carbs?
Make sure the bolts are tight holding the carbs down. I went to take mine off and they were loose. Believe it fixed the same issue as what you are describing. Just an idea though of course
