What were the diodes for?
I installed my trim kit today. Overall it was a pain in the ass. I'm taking the boat out tomorrow so I'll give some feedback.
I had to modify my ladder because it was in the way. I didn't see that coming. I also had to be a contortionist to get the hydraulic hoses routed in the engine compartment. I hope it's worth it. It cost just over $700
Is the tab mounted a little off? or is there a twist in the plate?
No way to mis-align the tab. It used four existing holes on the jet pump for mounting. No twist in the plate either. Both cylinders are fed in parallel so it can't be a problem with the pump. I'm thinking the left one must be weaker than the right one. I sent an email to the manufacturer. I bet they've seen this before. Hopefully it's a simple fix.
I tried the switch that came with it. Same problem.
I sent the Place Trim System back. He was very helpful and we both agreed that I probably wouldn't be happy in the long run. Basically it was an $80 trial that failed (Shipping costs both ways). After the money was refunded to my cc I ordered a set of Lenco trim tabs. I installed them this week and tried them out today. Wow! I love them. What a difference. I couldn't be happier. With the optional LED tactile switch controls this kit cost me under $650.
Just to be clear, I highly recommend Lenco's trim tabs. A special thanks to Al H. for his help.
I was on the fence to begin with and was talked into the Place system because I read the posts in this forum. I wish I would have went with the tabs to begin with.
I have had the same Place system on my 2001 Challenger 2000 for about 5 years with the pump mounted almost exactly the same way.
My problems are similar and more. 98% usage is saltwater.
My boat pulls to the left also, but it did that before I installed the Place unit.
The cylinders are built for compressed air service at 100 PSI. The hydraulic application here is somewhat higher pressure. The rod end seals fail. Don't get caught leaking oil!!!
The end of the cylinder where the rod exits has a bronze bushing for wear properties. Fine for air service, but not marine. 3 dissimilar metals are an electrolysis problem.
The cylinders only last about 18 months. Replacements on ebay or from Grainger or MSC for $15 - $30 each. Cylinders are not repairable.
