Venturian1
I agree with mikidymac 100%. 1. pull the jet pump, then try to rotate the engine with the spark plugs out. All you need to remove the pump is two 10mm open end wrenches for the steering and reverse gate, (two bolts with lock nuts), then a 13mm socket, 6' extension, and ratchet wrench to remove the steering nozzle (4 bolts), and finally, a deep 17mm socket to remove the 4 bolts holding the jet pump to the hull, then pull out the pump. (In rare cases the pump may be glued to the hull with silicone. Now, with the pump disconnected from the drive shaft, If you can turn the engine by hand with the PTO flywheel -spark plugs out, your problem is with the pump, or maybe the drive shaft wasn't inserted into the impeller or the rubber plug in the end of the driveline came out and turned sideways and is binding the impeller.
If you still can't turn the PTO flywheel by hand with the spark plugs out. either the engine is seized or the starter is binding or loose.
I own a 97 GTi, and the starter can be removed without pulling the engine, but you'll have to disconnect the battery, remove the jet pump, remove the 4 engine mount bolts, and if there is shims under any of the motor mounts, remove them and keep track of where exactly they go.
Now the engine can be moved, to accommodate starter removal. You'll need a 13mm 3/8" drive socket (not deep), about a 12' extension to get the two starter mounting bolts out, then a 13mm open end wrench to remove the shorter bolt that bolts the starter bracket to the engine block at the rear of the starter. You can disconnect the fat positive cable from the starter after you move the starter away from the engine. Be careful not to disturb the drain hose attached to the lower engine block that's in the vicinity of the rear bracket.
Now with the pump out and starter off try to turn it by hand with the spark plugs out. If it still won't turn, you may want to think about a different ski.
There's lots of possibilities.... a nut or washer, or ? got dropped into the carb and is locking up the rotary valve, or, water got into the crankcase and you bearings are rusted solid, or the oil injection system failed and a piston or two have stuck rings.
