no spark
rjquinn
ive got a 2000 gti and i was driving it just cruising and all the sudden lost all my power and jet ski slowly started to shut off… i got back to the shore and i still have compression but no spark, i have power going to the rear electrical box but no power coming from it. what do i do to fix this problem? i cannot find the whole box online anywhere. any help is appreciated
could be a bad dess post, or lanyard,,,check wiring,,connections,,,all grounds, all fuses,,,rear box first,,,,,,test the trigger/pickup coil, if it goes, there is no signal to the cdi then to the coil in the black electrical box,,,remove the rear ebox,,,put a test light on the white pulse to ground,,turn it over,,see if it pulses,,,if yes,,,the issue is in the box,,,if no pulse,,issue is up stream..
