One of my GTXs has a curious issue. I rebuilt the carbs recently due to poor performance. Reinstalled them and it ran perfectly. I got RPMs in the 6.4K range with good pop out of the water. Don't blame my wife but she took it out, ran good for around 10 minutes and suddenly dropped to 2K and limped back to our lift. It sat for about and hour until I had time to look at it. It will turn over but did not try to hit at all. Since then it has had no spark. I checked the compression-all good. I pulled the plugs and replaced with new-no change. I have checked the fuses-all good. I have looked at the rear box and do not see any issue with either the ground to the battery or any of the connections inside-- nothing. The voltage while cranking is good. I have swapped the front box with a spare but have not had time to program a key to it so will do that tonight. Any other thoughts?? If I still have no spark after all of that then I am thinking my only other option is the stator sensor and I really don't want to pull that cover off if I do not have to.Thanks!
