daredevil95
Hi, I have a 1998 GS 720, I've been throwing parts at this for the past 2 weeks. Ran fine the first few times this year then, it wouldn't start so, I hit the start button and got nothing....no sound from engine but, start button relay of something was working by the button so, I changed the plugs, wires, boots, coil, solenoid & rear electrical box wiring harness. It started right up and ran decent in the driveway and once in water....bogs or breaks up while having no power. These conditions are in the video below. I removed the jet pump housing, installed new wear ring, lubed everything and all is good. Removed driveshaft and it's straight and carbon ring seal / bellows are good.
Tried it in the water this afternoon (video) and it still breaking up or something. The only other items to tackle that I could think of is removing the head and decoking? or carburetor? IDK.....In the video below, shows the craft breaking up on the water, I used a boroscope camera to video the inside of the cylinders and compression ratio of 136 psi. I'll appreciate any and all advice?
