So the test is 5 minutes in reverse at the 1500 rpm. Each line should pump out 5.7 to 6.9 ml.
Could the vent above the tank be the problem?They are on the intake manifold/rotary cover fittings.
The one above the tank is just a vent.
It’s not the vent, it checked out fine.I guess in theory it could. I would have to look to see if it allows air into the tank or air to escape? Bench test the oil pump then that will be crossed of the list, If you want take the cap off the oil tank and that will eliminate a possible bad vent valve on top of the tank although I highly doubt that is the issue
the pump seems to be pumping fine but it only pumps the oil really fast when it’s mainly air bubbles. I’m hoping someone has another idea. I’m dreading taking the pump off again.I guess in theory it could. I would have to look to see if it allows air into the tank or air to escape? Bench test the oil pump then that will be crossed of the list, If you want take the cap off the oil tank and that will eliminate a possible bad vent valve on top of the tank although I highly doubt that is the issue
Sorry for my ignorance but where would those be located at?I would make sure the fittings on the intake manifold are clean and clear.
I know @etemplet had some that were troublesome.
Oh, okay. Where the oil lines connect to on the motor from the pump. Got ya. When I replaced the lines, they looked clear. Is there a way to remove that fitting the lines connect to?Follow the oil lines to under the throttle body and to the intake manifold.
Sorry, I forgot to give you all an update. Yes, it was the fuses at the back of the ski. I actually had three that were blown (2-20amp and 1-1amp). I replaced the two 20 amps and everything works just fine now. I took it to the lake for a quick 5 min run. I had to order the 1 amp as nowhere close had one so I'm waiting for it to come in. I am surprised that my main gauge is working with that 1 amp fuse blown. From what I've read, that 1 amp is what gives power to the front gauge cluster. My speedo hasn't worked since I bought it. The fuse is still in place so maybe it isn't actually blown. There is quite a bit of corrosion. I'll look at it closer. If it is blown, I'm wondering if maybe that is part of my speedo problem.Check your fuses and the MPEM. Then check the battery connections.
Basically the front console should work if:
You have power from battery to MPEM (computer in the watertight box)
You connect the DESS lanyard
So if that's not working you have some issue between battery, computer, DESS, and the wires between.
Let's hope it's just a fuse.
