Seadoo Tuner
Tried the 115g gold spring, cutting a bit off to lower it from 32psi but a failed experiment, not confident using it after trimming and didn't drop much so in the trash bin it went.
Confirmed the spring in the carb was in fact the 65g shiny silver like I thought after measuring it, popped off at 18psi and is likely the reason the SPI was bogging from idle. Have used the black 80g spring now and with the 2.0 needle have it consistently popping off at 22psi so hopefully that eliminates the bog and performance is better on the first 1/4 of the throttle range.
