flowmasterman
Just wondering, when I took my exhaust off, I removed the motor mount bolts on that side to lift the motor up a bit to remove the exhaust pipe, it has( whats left of it) a shim on the front mount. On the parts diagram it shows this to be the only shim used, and it 1.3 mm thick, what is this for and what does it do? Could this shim being bad be causing my problem of the bolts breaking in my exhaust?
