Danosll
Hi guys I have single 787 1997 challenger 150 psi compression . Appears to cavitate badly out of the hole. I have a new carbon seal and bellows very tight no water intrusion . Rebuilt pump and wear ring. Stock impeller without any nicks or dents. Motor revs to 7300 rpm. Have to back off throttle to plane. Here is my question. When I measure clearance with feeler gauge I have .020 at inside and outside tips but almost at limit at the center of the impeller. Again wear ring is new. Is this normal or has my impeller been reworked. Would that cause the over-reving/cavitatng. If I do need to change impeller what would be a good alternative to stock. I would want as much bottom end as possible. Thanks in advance Dan
