That's nice mine is about .035 there and .020 at outer edges with new OEM wear ring . and my impeller looks impeccable. Let me know what your hole shot is like . maybe I will go with OEM impeller. Which I can purchase locally.instead of wasting a week or two to order one.
Just got back from cottage .Solas impeller actually touches wear ring so I spun it around a bit so seat it. No more cavitation pulls good.
But now I can only pull 5500 rpm ( over 7000 before on bad impeller)maybe 6000 by myself. Impeller is a solas sd-sc-xo 16.5/23.5. And a bad intermittent miss at 1/4 throttled onto believe the two are related. Compression is 155psi. New plugs . Cleaned carbs and filters .changed 1 broken rave and cleaned other one . Plugs appear to indicate proper fuel air. Anyway I'll look into fuel system again tomorrow.
DanosII, I hate to say this but I'm wondering if maybe your original impeller was ventilating from an air leak at the carbon seal?
If that were the case, wouldn't this higher pitch Solas still pull air from the hull as well?
Yeah, I'm not sure exact;y at which point he replaced the carbon seal. He said he has a new one but not sure if he installed it with the original impeller.
I bought the boat with a seized pump. Appears that the previous owner replaced impeller and wear ring but the O ring on the cone was unseated that allowed water infiltration which in turn seized pump . I think he thought it was motor. Because plugs were out . So I rebuilt pump and elf touring and impeller because both looked new and were within spec. After initial run cavitated. So I used freezer method to change wear ring. Still caviated. So I changed impeller. Now no cavitation but the extra load is showing up an underlying problem that was always there but took the extra load to surface.
Paid $1700cad for the boat and recent shore lander trailer. boat is very clean .was always covered. No oxidation and seats are nice. Has original cover. We have a blast with it at our cottage. So i don't mind putting a little time and $ into it.
