Some guys fill the rivet holes, so in case your turf ever starts to lift, it won't leak into the hull.
I didn't. Or, maybe I did...with contact cement...:reddevil:
I will be applying new turf to my boat this week. This time I bought it with the 3M adhesive already on the back. I have applied surfboard traction for years and it is pretty much the same thing. But with the turf on my XP, I had to apply contact cement and there were a couple places where you can see some excess glue, and when contact cement is adhered, you are done, no corrections.
With the 3M, there is a little more forgiveness. Plus, since it has the wax-paper backing on it, it will not stick until it is peeled, so you can peel just a little 1/2" corner an lay the waxed part down to the boat til it is exactly where you want it, then press down that sticky corner. Then double check that it is still where you want it and start to peel back another couple inches at a time and sorta roll it out until it is all layed. It should remain straight and where you intend for it to be unless you stretch it instead of roll it while laying it.
Gotta get my old stuff off today or tomorrow and start to clean off the old adhesive. THAT is the fun part...:ack:
