They were in most, but not all, 04-06. In 06, they are pretty mixed. I have not seen them in the 07's.
i have been reading everything i can about this issue for the past week or so. it seems that in 2006 and 2007 some 4tecs still had the hollow valves. mine unfortunately does. but 2008 has solid valves. so you are ok. to see for yourself you have to take the valve cover off and look with a magnifying glass to be able to see the numbers stamped on the top of the valve stems. taking the valve cover off is easy, just 8 bolts right on top. seeing the numbers is the hard part. if it begins with 72 then no good. 75 is good. also not to make you go crazy but there is also an issue with flywheel bolts that mine is affected by. i havent had any issues yet but i am going to talk to the shop that i use on wednesday morning and see how much to do a head exchange and put in the upgraded flywheel bolts. i definately dont want my engine to blow up.
Mike, on a new rebuilt motor don't you have to break in the motor so all the parts seat properly?
no use just clearing the fault, you have fix the problem too!!!I have a new problem too... Some electrical issue... When the motor has high rpm's it just suddenly shuts off... Check engine light comes on and it just sputters and shuts off when restarted... Took it to Miami and they plugged it in and clear the code and boom started right up but as soon as I got it on the water, same thing happened
Hello everyone! Bad Crankshaft Sensor! I'm going to change it soon! Will this finally be the end of my boat breaking every week? I really hope so! To be continued...
So what happened Mike?.. Did you get it fixed? Or what? No answer in over three weeks. You're a lousy story teller. I bet you're a Yamaha salesman.
