Gauges
Probably not since your boat doesn’t have oil pressure, water temperature and no speed pickup.
Everything on these goes through the mpem and only the OEM gauges read that.
You could rig up wires to the battery for volts and a fuel sender but you would have to figure it out.
I’ve heard of GPS gauge for mph, I guess my biggest concern is gauges would be RPM. While I’ve got you. If the gauges do work (maybe it’s an issue with fuses) are their kits to restore them a bit. They look like shit ‍
The only restoration thing I have seen is new film for the factory digital gauges that get burned from the sun.
An aftermarket GPS spedo would work.
As for rpm, you would need one for each engine and I don't know how the aftermarket ones measure spark.
