Is that from the factory? Where did you get this info?
That's from the factory manual. I have a 97 challenger when I get home will get part #
Interesting... this contradicts many sites out there regarding impeller pitch. Says that part number is for 96 SPX, HX and a few other models. Claims the pitch to be a 11/22. Skat Trac recommends a 17/22 Swirl for the 787 Challenger if one seeks to make it faster. Otherwise, they recommend a 14.5/22.5 Swirl for hole-shot. I was under the impression that the 787 Challenger stock prop part number was 204 160 027 according to http://www.seadoosource.com/impellerref.html
I have a seadoo book at home that has some prop part number to pitch crossovers. I'll reference your find.
are you absolutely certain you have an air leak at the shoe? silicone will blow right off from the thrust if applied topically.Do you guys think I can just seal the shoe at the pump? just take some strong silicone and go around right where it meets the hull around the the pump area? I really don't want to take it all the way off... That seems like such a PITA!
Have you tried a little heat with a small propane torch.
That usually loosens up the red loctite that the impeller was installed with.
If you get it loose and some of the threads are screwed up just get a M16 x 1.5 tap and dienut to clean up the threads.
