Prop suggestions / help
davus
Hello all.
I’ve changed the engine in my 2003 sportster from a 155 to a supercharged 260.
In doing so, I had to upgrade the driveshaft, and therefore prop. To get myself on the water I just grabbed the only prop I had lying around and threw it in (no markings of part numbers at all)….along with a new wear ring.
I managed to prove the point and get the boat on the water for a test, but as I expected, the prop is terrible, and cavitation is significant. So I need to swap it out.
The OEM prop for a 2012 260 150 (almost identical setup) sport boat is 267000992. So I figure I could try to find one of those, or something similar. however I have no idea of the pitch on the OEM prop.
Is anyone able to help with either a prop suggestion, or provide any info on the specs of the OEM prop so I can try to match it.
Thankyou
Reply
Report •••
Call Impros and they will set you up.
You really can’t go by pitch because every manufacturer measures them differently, there is no standard.
