IDoSeaDoo
Hey guys, I'm getting pretty discouraged with this boat. I finally finished rebuilding the motor, and that runs great. Got good compression on both cylinders, but am still investigating the 100degF EGT difference. No matter, the scope of this post is to address my propulsion issue. Since the beginning, I've had pretty bad cavitation with this boat. When I used to gun it from low speed, the engine would tach out and bounce on the stutter box until the boat speed had a chance to catch up. That was (I think) with a stock prop. Since then, that pump's wear ring, being old and brittle, started to come apart. I disparately tried getting the impeller off and ended up breaking two pretty large vices (of two brands, one Wilton, one Bessey). The prop is STUCK, and it will take nothing short of the highest ranking Jedi to "force" it off that hub. So I got another pump I had laying around, put a new wear ring in there and stuck the closest prop I had to the stock challenger stock pitch. It was off a 95xp and had the 10/22 pitch (challenger stock is an 11/21 I think). So there is a new wear ring, newish neoprene seal (I've had the pump off twice since installing it, but it was in good shape), good prop with sharp, straight blades (non-swirl), completely re-sealed/non-leaking weedless system, and an old-style driveshaft seal, like on the old 95's (not the carbon ring design). I don't think the driveshaft seal leaks air because it does not drip water, whereas the new carbon seal combo i bought from SBT leaked quite a bit.
So from stand still, when I gun it, it puts the nose of the boat in the air and pushes water for a good 30s while the engine STRUGGLES to plane it out. That is with just two ppl in there. The reason I say struggles is because it hits 7k rather fast, like at 3/4 throttle. I don't like running it that high when it's not planing, just feels wrong somehow, also I haven't fully broken the rings in yet. The boat will lose plane with me and another (about 350lbs combined) at 5k rpms, so it's either we putt around at idle, or haul ass. I feel that something is still wrong. There is no way anyone would buy a boat that ran like this. So what do you guys think it could be? Is the prop pitch that far off? Do ride-plates EVER leak? I mean, I suppose it's possible, but that sounds so unlikely! Could my driveshaft seal be leaking air, but not water? I'm almost at my whits end on this thing. I have a few more props I could try, like a 16/22 (or 23), a 17/23 skat trak swirl, a 17/25, a straight 17 and maybe some others. What should I investigate first? I feel that the boat is still "out-of-commission" at this point... HELP
