JeremyD615
Well the three wire tachs have two wires for power, which are probably good if you’re getting movement, and then the signal wire is just a pulse from one of the stator wires. It’s hard to see that pulse with a cheap meter, so I’d just do a continuity test on that wire to the stator. If it tests clean then you’ve probably got a bad gauge...
