97 XP here
Starts great, runs great. Go about 50 yards and it dies with zero warning. Engine turns over but won’t crank. After a while it will start again, but the same issue occurs shortly after.
Fuses all look good. The 5 fuse was making a different beep sound than the others so I switched it out.
Battery is showing 12v while running. When you rev the engine, it goes up to between 12.6-12.9v….never into 13 or 14v.
Is this a stator and/or rectifier issue?
Thanks for the help!
