i just rebuilt my 97 xp after i blew the engine on the water. did whole top end rebuild with professional porting and oversize. then i installed the microtouch rev limiter while keeping standard settings. then removed all grey lines and replaced with nice black ones. i installed everything when i did rebuild. when finished, tested the machine outside of water. we had to run it for 2-3 hours on idle to do correct break-in. machine runs perfect outside of water. once in the water, the machine idles fine but when i kick it into powerband, machine "runs out of fuel" feels like starving and dies down. it starts back up no problem and can do the same thing again. running oversize carbs and type 2 exhaust pipe. carbs have been cleaned and lines are new. i removed elbows right after fuel sender under the seat, is it possible i have kink in lines? i looked and looks fine. maybe microtouch system? the other day i reved machine and it overreved on its own even after removing key, few seconds then died: weird? why does machine cut out? everything is new.
please help!!!
please help!!!
