BlakRat
Hello, I just put a fresh 787 in my SPX... I set the carbs to stock needle settings and run pre-mix as well as the oil injection for the first outing... The thing ran great but fouled what i think was the rear plug ... It started vibrating and seemed like it cut down to one cylinder after about a 2 minute full throttle run, it started running fine again when I started alternating the throttle setting again... both plugs had a brownish sootie look to them but the PTO one was wet and the Mag one was dry... When I got home and flushed it on the tap, I also noticed that the rear cylinder was running very cool and the front was very warm to hot... Whats going on with the variance between the two cylinders? Should I give it a little more fuel to the High end of the Mag cylinder or lean the PTO side?
Thanks, Dave.
Thanks, Dave.
