Hello,
I picked up a 97 GSX (787) a few weeks ago. I got it cheap in "not running well" condition. It wouldn't get high RPM's without adding some choke while on the throttle. I checked the compression (140&141) and decided since it ran great if you get the choke just right I would rebuild the carbs.
I followed the "carb rebuild thread" and have rebuild carbs before so I'm pretty confident I did a good job. Everything inside looked pretty good, I used a genuine Mikuni kit. Also went ahead and replaced all the Tempo fuel lines while I was in there.
Today I had some time to get it all put back together and it's pretty much doing the same thing, though it is idling better now.
To go into a little more detail of the problem: while running in the water (river) it idles perfect at 1,500 RPM, but as soon as you give it some throttle it only increases RPM to about 3,000 and just maintains that RPM until choke is applied. If the choke is just right it will get to full RPM's and runs great (while holding choke).
After running in on the water I pulled the plugs (new after carb rebuild) and they are both showing very rich condition, which doesn't' make sense to me because needing choke should be lack of fuel. I also verified that the oil injection pump is adjusted properly, if anything it's leaning a little to the lean side but it's pretty darn close to dead center on the alignment marks.
I'm leaning towards it being an issue with the fuel pump, though the thing is so darn simple I can't see how i would have messed up the rebuild.
Any input is greatly appreciated.
Thanks!
Thanks!
