Well I’ve got good water flow now, but it is still dying at full throttle. It runs strong until I get up around 6K, and then it just falls on its face. It feels like the lanyard was pulled, but if I feather the throttle, I can keep it from dying completely most of the time. When it does die, it seems to fire right back up and run okay until you get the revs up again.
I know this sounds like a fueling issue, but it just feels electrical to me. The DESS post is new, and you can hit the start button and it fires right up without touching the lanyard after it dies. It will even start up before it slows down enough to come off of plane.
The carbs have been rebuilt with Mikuni parts including new needles and seats, and all of the fuel lines have been replaced. I didn’t replace the fuel selector, but I did blow it out and it seemed to be obstruction free. The fuel water separator is original as well, but the o ring is in place and it’s threaded on tight. Rave valves are cleaned with new soft parts as well. Of course I just went through the water control valve, and it seems to be functioning correctly now as well.
I’m thinking it could be the rectifier. It does seem like the battery gets a bit weak after riding for a while, and I really have a gut feeling that it’s electrical rather than fuel. It seems way too much like an on/off switch to just be a plugged up fuel system, and almost all of it has been gone through. I also pulled the plugs, and the mag side is richer than the pto, but I don’t think it’s lean by any means. The pto plug has a nice rich brown color like I would expect to see.
Anyone have suggestions?
